[quote="Indiana Ken"](quoted from post at 10:11:52 01/25/13) Quoting Removed, click Modern View to see
It is basically a solution in search of a problem that you are not likely to ever see. It really only applies if the alternator wire on the #2 terminal is connected remotely such as at the starter solenoid instead of the alternator output terminal. Connected remotely gives better control over the battery voltage than having it connected at the alternator.
Connect them in parallel.
When starting the diode will provide low resistance to energize the alternator. It will also prevent any current from flowing back to the switch which ensures that the switch can control the power to the coil.
The problem with having only a diode in the circuit to energize the alternator is if the wire between the alternator output and the battery should become open all the current would be fed through the #1 terminal back to the switch. With no path back to the sensing wire the alternator voltage will rise until it destroys the alternator. The resistor allows some of the current to flow back through the circuit so the sensing wire can still control the voltage but limit the current to prevent over loading the circuit.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
