Re: in frame rebuilt c123, very hard to turn over...normal?
Posted by Dave Allgire on January 26, 2013 at 05:25:19 from (96.35.208.3):
In Reply to: in frame rebuilt c123, very hard to turn over...normal? posted by PretendFarmer on January 26, 2013 at 05:00:12:
You don't say whether you installed new rod/main bearings. If you did, are they the correct size? Did you overtorque the rods that you had out? Just a couple of things to check. An easy way to check is to turn the engine over by hand after torquing the rod you just torqued before moving on to the next one.
