Re: siezed clutch?
Posted by Tom Fleming on January 26, 2013 at 05:35:26 from (67.20.233.75):
In Reply to: siezed clutch? posted by PretendFarmer on January 26, 2013 at 04:11:40:
Well, the clutch disk could be rusted (stuck) tot he fly wheel. Are you doing an "in tractor" job on the engine? I would think so, since you would have to remove the clutch (or at least see it) with the engine removed. Remove the lower inspection plate to see what is going on if you have not removed the engine. You should have approx 3/4" - 1" free travel in the clutch pedal to be correctly set.
Need more info.
