Re: F-30 Electric start
Posted by Duner Wi on January 26, 2013 at 05:44:10 from (216.226.80.242):
In Reply to: F-30 Electric start posted by Mark Poss on January 25, 2013 at 19:06:41:
I don't know who made it but 1955 Central Tractor Parts Co lists a starter assembly for F30. Part # CT1331 $44.50. Kit has starter,flywheel, bolts and bracket to hold starter that bolts to frame. 40 to 50 minutes to install.
