Re: in frame rebuilt c123, very hard to turn over...normal?
Posted by gene bender on January 26, 2013 at 06:25:55 from (67.55.226.151):
In Reply to: in frame rebuilt c123, very hard to turn over...normal? posted by PretendFarmer on January 26, 2013 at 05:00:12:
Do you have good oil on the pistons you dont want them to be dry as some smoke after starting wont hurt a thing. Sounds like you did OK
