Re: Farmall BN, two questions
Posted by Tom Fleming on January 26, 2013 at 06:42:25 from (67.20.233.75):
In Reply to: Farmall BN, two questions posted by kopeck on January 25, 2013 at 07:36:39:
well, then the lube is not old and dirty. There is a carrier bearing at the front input of the tranny. Could be going bad. Could have had grit in it. Could be a number of things.......some not too bad, some worse as they would require opening up the tranny and replacing bearings.
before you go to far, at least take the top off and see what she looks like inside. Yes, condensation can be an issue.
