For sure if the trans is turning and it is less than 50 degrees where the tractor is located, it will be way hard to crank with the trans lube being stirred!. Pull it is OK if you don't try to start it till the clutch is loose. Block down the clutch then (ignition off) rock the tractor hard in road gear. If no joy, with the clutch blocked down) lock the brakes or block the wheels if the brakes won't hold, and use 12 volts on the starter to break free the clutch. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
