Re: siezed clutch?
Posted by ken house on January 26, 2013 at 09:32:00 from (173.242.241.169):
In Reply to: siezed clutch? posted by PretendFarmer on January 26, 2013 at 04:11:40:
i assume that the engine will run. if you have wide open space available and a hill, get the tractor on the hill, heading downwards; get on the tractor, put the tractor in 3rd gear and start it. drive around with your foot pressing the clutch pedal. maybe it will come loose. throttle the tractor up and down, press the brake pedals and then release them. be careful doing this, make sure you have plenty of space.
