Re: 1953 SM Correct Dash Box?
Posted by D Slater on January 26, 2013 at 13:25:15 from (184.15.43.165):
In Reply to: 1953 SM Correct Dash Box? posted by pete_5959 on January 26, 2013 at 11:47:31:
You have the correct one. Serial numbers F-28175 and L-504802 and higher used that setup. Below the numbers were just like the later M tractors with the voltage regulator mounted to the rear fuel tank support.
