Re: 53 Super C, Spring in cyl head
Posted by Janicholson on January 26, 2013 at 14:38:39 from (199.17.6.95):
In Reply to: 53 Super C, Spring in cyl head posted by WK-WA on January 26, 2013 at 13:38:23:
If you take an old plug with the ground terminal filed or ground off, and insert it till it is just flush with the inside of the combustion chamber, then use a dremel tool to grind off any exposed helicoil, it will be best practices. That exposed coil can get hot and cause preignition. Jim
