Re: siezed clutch?
Posted by oldiron29 on January 26, 2013 at 14:59:42 from (74.88.11.200):
In Reply to: siezed clutch? posted by PretendFarmer on January 26, 2013 at 04:11:40:
Pretend, If your clutch is stuck and spinning tranny and you have real cold gear oil you could have found why you engine is cranking slow.
oldiron29
