Re: siezed clutch?
Posted by Dennis K (WA) on January 26, 2013 at 19:41:14 from (24.21.78.195):
In Reply to: siezed clutch? posted by PretendFarmer on January 26, 2013 at 04:11:40:
If it has an inspection cover, grease access, hole like the older models;
With engine off and another person holding the clutch pedal down, go through the hole with a punch to the hub of the clutch plate and rap it hard with a hammer. Unless it is severely stuck it will free itself.
Another possibility is the pilot bushing in the flywheel, but not as likely.
Dennis
