Re: rear axle housing gasket on a regular
Posted by Fixerupper on January 26, 2013 at 20:54:53 from (100.42.82.30):
In Reply to: Re: rear axle housing gasket on a regular posted by Old-F20 on January 26, 2013 at 20:32:35:
I do have black RTV and it is a good way to seal it up. I might be a little too particular for my own good, but if there was a gasket there origionally I tend to lean toward making a gasket for it. Another thought I had was this sealer CIH has for sealing the surface where the axle housing meets the rear end casting on a 1086 and similar models. You probably know what I'm talking about. Comes in a little squeeze tube and is purplish-red in color. This stuff was used in place of a gasket when the tractor came from the factory but It could be the tolerances and warpage might be wider on this old tractor than they are on a more modern one. Jim
