Posted by Janicholson on January 27, 2013 at 08:20:01 from (74.60.94.18):
In Reply to: Farmall B Starter posted by Vette Man on January 27, 2013 at 07:37:30:
The starter should have a mechanical (saddle) switch on the top side of the motor. It is just a heavy current momentary contact switch. Normally there is a actuating rod from the platform to the switch to make contact. Seats are often found on Ebay. Putting an ad in the classifieds (to the left also works wonders. Seats can be reupholstered in reproduction cloth to be very original. Go to caseih.com Select your country, select parts at the top menu bar, scroll down to find the case IH parts store. select find parts by model, then a second find by model button in the center of the page, then select the icon with the small magnifying glass , which is next to the browse button. then put in Farmall. neither an A nor a B have illustrations of the switch and rod, but there is one for a C Farmall, so select C. Then select electrical System. There will be a image of the Rod controlled starter. Some are pull rods like that one, some are push rods. If your saddle switch is push, it will need 1/4 inch rod to make it. if pull, 3/16 rod will work. You might find one on line as well. Best of luck, Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
