Re: 656 Thoughts
Posted by Janicholson on January 27, 2013 at 08:30:43 from (74.60.94.18):
In Reply to: 656 Thoughts posted by IAtractorKid on January 26, 2013 at 21:51:59:
It looks like it will clean up very well. They work hard. If you keep loads low when transporting (necessary with wide or narrow), the narrow front is just fine. If a wide front tractor tips far enough to hit the stops you are making incorrect decisions as to where you are driving. THe pivot point on a wide front is the axle pin in the middle of the bolster. The pivot point of a narrow is the tire to ground on the side where the tipping force is applied. Not much different. If the price is reasonable buy it. Jim
