Re: farmall f 20
Posted by robgIN on January 27, 2013 at 09:24:48 from (70.224.37.82):
In Reply to: farmall f 20 posted by kevin s on January 27, 2013 at 09:17:41:
the frame is longer on an F-30, the clutchshaft and coupler are bigger than the F-20 also, the radiator is bigger on a 30 and fittings are different as the 30 uses a water pump instead of the thermosyphon, so no. With some work you could do it but not going to be a direct swap by any means.
