Re: 656 Thoughts
Posted by Weldon K on January 27, 2013 at 13:43:50 from (98.16.29.121):
In Reply to: 656 Thoughts posted by IAtractorKid on January 26, 2013 at 21:51:59:
Need more room to get on /off the tractor? Spread the rear wheels farther apart by two methods. Attach the rims to the cast wheel centers using the mounting beads, on each rim, that are toward the center of tractor. Or slide the cast wheel center outward on the axle. Wider wheel spacing also makes it safer . Fill the rear tires with fluid if not already filled.
