Posted by cleddy on January 27, 2013 at 14:23:22 from (174.74.54.243):
In Reply to: Re: 656 Thoughts posted by ss55 on January 27, 2013 at 13:31:05:
As mentioned in a previous post I just put this loader on a tractor and they are quick-tach. You can adjust them forward (12-15"in front of wheel in my case)by telescoping the tubes that go to the axle horns. To mount you drive into it until the hooks enter the horns mounted to the axles with big bolts-Hook the hydralic up and lift the mid section until it goes in the center brackets(2-3/4 bolts on each side) and pin them and then hook the front braces up to brackets in front(4 bolts each). After brackets are mounted dis-mounting is 2 front hooks and 2- 1" pins in center and hydralic hoses and back out.
I agree it may not be a good match since loader is so heavy (1500-1800lbs) but I'm sure price is way lower than new.($8000.00/New Westendorf loader only) I have set up instructions and an advertizement featuring this loader on a 560 IH tractor. cleddy
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
