Posted by CNKS on January 27, 2013 at 17:26:27 from (216.144.104.128):
In Reply to: 300 progress (a little) posted by Zachary Hoyt on January 27, 2013 at 13:55:33:
If you put back the original gears, or if they are a matched pair, use the original shims, if you don't there will be a new pattern and the gears will be noisy -- in other words don't try to adjust them, as has been said by others on this forum. A couple of years ago I replaced all the bearings in my Super A trans meaning a complete disassembly. I didn't like the clearance or backlash and ordered 2 or 3 new shims, still couldn't get it adjusted right. So, I put the old ones back in the original order, and decided not to try to adjust it. Has more then the "new" backlash given in the manual, but has no excessive noise. If none of what I just said does not apply to your situation, it may not, ignore it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
