Posted by rankrank1 on January 27, 2013 at 19:49:41 from (198.228.228.152):
In Reply to: 656 Thoughts posted by IAtractorKid on January 26, 2013 at 21:51:59:
I was thinking more along the lines of adding a high output fan belt driven hydraulic pump. I would not want to tie up my PTO with a pump in case you wanted to run an implement off the PTO later. Running off the belt the hydraulics would be both fast and live.
As for the PS rob that system from the Super H before you sell it.
3-points come up for sale used all the time. I recently picked up one for $300 and simply love it.
Wide front? Well I disregarded that totally since the 656 had NF too so not really a deal breaker. And to only push snow... the narrow front is much more maneuverable anyway.
T/A not really sure how useful that is on a loader tractor. I always thought T/A's were mainly for plowing or heavy tillage. In other words Run in high 95% of the time hit a hard spot when plowing pull the lever back to get through the hard spot and then push lever forward to high once through the hard spot. I guess they technically do give you some slower speeds but they freewheel in low range too so not really meant to drive there much from a safety aspect when doodling around.....freewheeling will not happen with a plow in the ground behind yah so no worries on using T/A then.
I think I would rather have the 656 over the 400 though if you dead set on trading. But to only push some snow around every now and then; I think I would rather have your M and either $2000 to $2400 or so in my pocket (assumes you get $3k total from sale of both h's and then spend say $600 on hydraulics and $400 on a 3 point). If I read correctly earlier your m also has brand new tires all around as well so that's a good thing too.
Anyway good luck on whatever happens....any of them will certainly do the job.
This post was edited by rankrank1 at 20:01:08 01/27/13 2 times.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
