Re: 656 Thoughts
Posted by mkirsch on January 28, 2013 at 05:07:40 from (64.80.110.74):
In Reply to: 656 Thoughts posted by IAtractorKid on January 26, 2013 at 21:51:59:
You sure you're thinking of the right tractors?
656 is a small frame tractor based on the 460 with mechanical TA, mechanical brakes, 5-speed transmisison, etc..
756 is the large frame tractor based on the 706/806 with hydraulic TA, hydraulic brakes, 8-speed transmission...
About the only place where repairs would cost the same is the engine. Everything else should be less expensive on the 656.
