It's probably coming from the pinion/ring gear. The transmission is actually making noise in all gears, but you only hear it in 5th on account of the much higher RPMs.
Most likely cause is misaligned gear mesh from worn bearings. But it also could also be from improper pinion mesh adjustment when the transmission was assembled, or simply (unlikely) the ring/pinion have worn out.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
