Re: 300 progress (a little)
Posted by Zachary Hoyt on January 28, 2013 at 13:46:19 from (74.47.60.18):
In Reply to: Re: 300 progress (a little) posted by D Slater on January 27, 2013 at 19:41:44:
Thank you very much for the detailed advice. I tried putting the input shaft in place but I found that there was still about the same amount of play on the main shaft since there was only one bearing on each shaft that was anchored in the housing. I went ahead and put the TA back in the housing and got it moved back over by the tractor and tomorrow I will put it in place and see what the pattern is. I have not been able to find a way to remove the bull gears or the bull pinion carriers separately on the 300, I seem to have to unbolt the carrier, slide the axle out of the bull gear and then rotate the carrier toward the front of the tractor so I can lift the bull gear out and then slide the carrier out. On the Hs I have had apart I could remove the axle and then roll the bull gear back to allow the carrier to slide out, but there doesn't seem to be room on the 300.
Zach
