Re: H Belly Pump Cover
Posted by pete 23 on January 28, 2013 at 16:49:15 from (74.32.229.189):
In Reply to: H Belly Pump Cover posted by JCR-Michigan on January 28, 2013 at 14:51:42:
The plain one is for tractors with no hydraulics, the other would be for a super with live hyd pump as culivator, corn picker etc would have part of the lift mechanism fastened in the slots. I don't think the old mechanical lift cultivators used that but could be wrong on that. You could easily fashion a heavy sheet metal cover as those cast ones are pretty scarce at least they are around here.
