Re: Touch control overhaul
Posted by farmallhal on January 28, 2013 at 18:02:52 from (76.4.183.119):
In Reply to: Touch control overhaul posted by Rick Remmert on January 28, 2013 at 17:34:45:
I think you should forget about putting a vent hole somewhere in the unit. Where pressure can escape contaminates or moisture will also have an entry point neither of which should be in the system. I believe if a vent was required one would of been provided by the engineers who designed the system and unit. If you don't over fill the unit above the proper level (1/2" below the bottom of the fill plug hole) there is probably sufficient room for any expansion due to pressure and heat which might build up during use. Good luck but you should find your unit works correctly after being cleaned and new o-rings and seals installed, Hal.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
