Removing brake drum on an H
Posted by Brad in WI on January 28, 2013 at 18:15:31 from (108.167.253.68):
I am trying to remove a brake drum and it is not co-operating with me. I have the early style drum that has the the key. So far I have only tried prying it off with bars opposite of each other (worked on other side) and applying minimal heat with a propane torch. Any suggestions on what else I can do to remove the drum? I am putting in new bearings and seals so I am not worried about burning them with a hotter heat source. I do not have a puller but might be able to find one if that is the only option to get it apart.
