Re: Checking oil levels in 1950 Farmall M
Posted by The Red on November 05, 2000 at 09:12:51 from (12.75.196.96):
In Reply to: Checking oil levels in 1950 Farmall M posted by hillbilly on November 05, 2000 at 08:46:27:
Congrats HB! On the engine oil pan, on the distributor side, there should be two oil gauge valves. The oil level should be maintained between these two valves. Open the lower one. If no oil drains out, then you need to add oil. The engine holds 8 quarts. Note there is a large 2 1/2 inch diameter filler cap that is right of the distributor assembly. That is where you add oil.
On the transmission, there is a side drain plug near the clutch pedal. If 90W pours out from this plug, the transmission is full. It holds 13 gallons of 90W. The filler cap is near the base of the steering wheel post.
On the oil bath air filter, there is a line on the cup which shows the proper level of oil.
Post A Followup
: Re: Re: Checking oil levels in 1950 Farmall M
