Re: Differential tooth pattern-not sure what to do
Posted by rustred on January 29, 2013 at 10:08:31 from (69.58.16.5):
In Reply to: Re: Differential tooth pattern-not sure what to do posted by Zachary Hoyt on January 29, 2013 at 08:42:12:
kinda looks like your not that far out.
i would wipe the pinion clean from blueing and just coat the crown gear lightly and try it again. rock the crown gear back and forth , where the blueing is removed that would be the contact point. should invest in a dial indicator, would be handy. it is hard to guage thousandth's by feel but after a while you get in the ball park. you want the pattern centred towards the toe of gear ( narrow end) as under load it want to move towards the heel(wider end).
may as well have a better look at things.
