Re: Simplifying hydraulic plumbing on Stage II Super M?
Posted by mkirsch on January 29, 2013 at 12:31:51 from (64.80.110.75):
In Reply to: Simplifying hydraulic plumbing on Stage II Super M? posted by TSEliot on January 29, 2013 at 12:22:44:
Sure you can bypass all that. The two hoses to the far right of your picture are the pressure and suction. Just connect the pressure to the IN on your Dual loader valve, and the suction to the reservoir.
That will bypass the factory hydraulics.
IF you want to get rid of the reservoir... wink-wink, nudge-nudge...
