Re: Parts found in drained Hy-Tran on a 706
Posted by John V. on January 29, 2013 at 12:38:37 from (76.16.5.245):
In Reply to: Parts found in drained Hy-Tran on a 706 posted by John V. on January 29, 2013 at 12:08:45:
Could this explain why I hear a knock when then transmission is in low range, like it isn't fully engaged?
