Reason the pressure line going on to the liftall unit is teed at the valve is because the pressure relief valve is in the liftall unit. Unless you tee off the pressure line also you need a pressure relief some place else. Only reason the suction line is teed is for the return fluid back through the remote control valve when using it. But if you keep useing the liftall unit for pressure relief you also need a suction line from it for bypass fluid to return. If wanting to bypass all of the liftall parts, the loader needs to have a relief valve or one added in the pressure line with dump to the suction side or the loader tank.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
