Posted by farmallhal on January 29, 2013 at 17:49:57 from (76.4.182.41):
In Reply to: Re: Headlight gromment posted by OldMoIron on January 29, 2013 at 16:31:56:
If you are referring to the spacer it will be steel and about 3/8" to 1/2" or so long with a hole a little larger then the 1/2" stud on your lamp to slide through. The outside diameter is probably around 3/4" or maybe a little smaller (not near one to measure). The spacer goes between the lamp housing and the lightbar clamp with a split locknut and hex nut on the bottom. Spacers are available from about anyone who sells parts for the letter series tractors. Hope this helps, Hal.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
