Re: STALLING 454
Posted by Jim Naden on January 30, 2013 at 03:07:57 from (12.74.49.164):
In Reply to: STALLING 454 posted by PRTZMAN55 on January 29, 2013 at 06:43:10:
No need to remove the tank.
Look down the fill cap with a light and you will be able to see if there is debris in the bottom of the tank.
To clean it, remove all of the plugs and fittings from the bottom of the tank,both sides, and remove the sending unit from the right side top of the tank.
Flush with water until all of the debris is out.
Blow out the remaining water, install all the fittings and plugs and fill with gas.
Best done outside where the water mess won't matter.
