Re: Fan Belt Tension
Posted by Bob R on November 05, 2000 at 13:02:36 from (198.133.22.75):
In Reply to: Fan Belt Tension posted by John on November 05, 2000 at 07:37:07:
You should have an adjustable pulley .You will find a screw with a nut on it . Loosen the nut and back out the screw . Then ajust by screwing in or out the pulley half . It will most likely be stuck . I took a torch and steadily used even heat and freed it . then coated the threads with anti seize compound ..
Post you results ...
Post A Followup
: Re: Re: Fan Belt Tension
