Dan, I have a 1953 Super C with the factory 2 point fast hitch which has down pressure and might have been the first tractor model with that feature. I can give you a couple of places where that feature is certainly very handy. One, you can place a block of wood under the drawbar and lift the back of the tractor off the ground to adjust wheel spacing to to remove a tire and rim. Second, when using a post hole auger it is a way to control how fast the auger can dig into the ground. When digging a post hole and a tree root or large rock is encountered the auger without down pressure will "screw itself" into the ground and will take considerable manual effort to extract the auger from the hole. A lot of people think the down pressure is great to force the auger into hard ground and that might be true but where I live I'm concerned with an auger getting stuck in the ground wrapped around an unmoveable object and having to hand twist it back out with a pipe wrench or similar tool. I control the speed at which it is fed into the soil with the down pressure control I have with the fast hitch. Hope this helps, Hal. P.S. Where in Missouri are you located as I'm down near Rolla - my email is open as well.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
