Re: Generator Polarize
Posted by John T on January 30, 2013 at 15:30:51 from (71.52.103.159):
In Reply to: Re: Generator Polarize posted by Don Mountain on January 30, 2013 at 12:34:29:
If the VR's internal cutout relay is failing to ever close and by pass jumping across it (BAT to GEN/ARM) makes her charge yeppers sounds like a bad VR HOWEVER that assumes shes all wired right and all polarities are correct (genny and ammeter and battery etc). While what you say (that pegged ammeter dont sound exactly right) and my test tends to say that Im still concerned all your polarities are correct because the more common VR cutout relay problem is them sticking closed versus failing to make up.
If the ammeter polarity (and battery) is correct, if you turn on lights or ign engine not running it ought to swing over to - discharge!!!!
Id say the jury is still out
John T
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
