Re: Ih460 wiring ,coil question
Posted by John T on January 30, 2013 at 19:22:25 from (71.52.103.159):
In Reply to: Re: Ih460 wiring ,coil question posted by LarryNMO on January 30, 2013 at 18:15:38:
"I did see some wording that said, use with external resistor"
If it says that my best "guess" is it means just what it says i.e. it requires the resistor or else it will overheat....Id try that coil WITH the unshunted external ballast n see what happens.
"Since the tractor has 12 volt system should I ask for a 6 volt or 12 volt coil to install on it?"
You can EITHER use a 6 volt coil PLUS the external series voltage dropping (12 to 6) working ballast orrrrrrrrrrrr a 12 volt coil with no ballast required. However to utilize the ballast by pass system for improved cold starting you would need the 6 volt coil plus a good ballast. Id be tempted to just use a new full 12 volt coil (NO ballast required) and do away with any ballast or by pass circuit headaches...
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
