Re: Got the 3-point mounted
Posted by Dan T in MO on January 30, 2013 at 21:00:03 from (166.181.3.184):
In Reply to: Got the 3-point mounted posted by Dan T in MO on January 29, 2013 at 19:49:18:
Thanks for all the replies. The power down idea was mostly for the blade. When I've used it with the 9N it will sometimes ride over where I want it to dig in. I currently have 75 pounds hanging from the blade, but figured some hydraulic preasure would let me be able to hold the blade firmly to the ground without adding weight. It's not a major issue, so power down really isn't needed. Saves me some bucks and gets the hitch working a lot sooner if I go for gravity down. Although, being able to lift the back end off the ground is mighty tempting.
I was thinking a plug might cause problems. I'll be sure to vent the upper side.
To the fella down near Rolla, I'm just a bit south of Eldon and a piece north of Lake Ozark.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
