Looseness of the Unloader valve is not an issue as you say that dead ending the auxiliary valve has no effect on the slow lift!!
I think the issue lies elsewhere but ideally need the pressure test!!
Dead ending the aux valve during lift, rules out all problems in the Unloader and flow control valve assy if there is no change to rate of lift ??
While you have unit on the bench remove the union and check the flow control piston and its spring?? This piston (only) is matched to the valve body and could give slow lift, but if it was responsible for your issue the lift would speed up when the aux valve was dead ended!!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
