Re: New to tractors
Posted by RTR on January 31, 2013 at 08:17:18 from (216.226.179.180):
In Reply to: New to tractors posted by James Dotson on January 31, 2013 at 08:07:25:
Sounds like the tractor has been modified (cobbled) over the years and is FAR from the original and correct set up. Detailed pictures of the Dash, serial number (plate on front steering housing), and some other info such as alternator or generator and 12 or 6 volt would also help. That tractor should have originally been red; not the yellow/white combo. Yellow/white came along in the mid 60's on a totally new new body style. That is also the incorrect seat for that tractor, so if you don't like it, that's why.
FYI, the choke lever is opposite the start lever and looks the same as the start lever. If you'll follow the linkage from the carburetor choke, you'll see where it goes. But like I said, who knows what has been changed!
We're here to help you!
This post was edited by RTR at 08:22:05 01/31/13.
