Battery Boxes (Top Cover) for H
Posted by AL Moyer in Pa. on January 31, 2013 at 11:41:42 from (173.62.239.32):
OK guys, Got a new battery box & top cover for my 53 Super H, battery box under gas tank, are you guys leaving the top cover off of the box ? The problem I have is that the rubber bumpers in the lid, are right on top of the battery post. Now I can take them out of the reciever in the lid, & that will let the lid fit the box, however the terminal & cable fitting is more than likely make contact with the lid in this spot.Obviously not a problem contacting the Possitive post(Still Possitive Ground), but not good contacting the Negative post. Tried two different covers, 1 with the off set bumpers, & the alined bumpers- same issue. Could have gone with a smaller battery, but would also be less CC amps & didn't fit/fill the box, So what's fix that most of you use ? Thanks as always for any & all suggestions. AL
