Re: 90# oil color
Posted by CNKS on January 31, 2013 at 18:03:43 from (216.144.104.128):
In Reply to: 90# oil color posted by WK-WA on January 31, 2013 at 17:35:42:
Most tractors that have been used and have not had the transmission oil changed in several years will have that color oil. Hydraulic oil will do the same thing. There can also be water underneath the mixture as you said. Mixed with water it is not clean, Replace it, a C is not like an M that uses 13 gallons.
This post was edited by CNKS at 18:06:38 01/31/13.
