Re: 90# oil color
Posted by Jim Becker on February 01, 2013 at 05:55:04 from (173.74.120.222):
In Reply to: 90# oil color posted by WK-WA on January 31, 2013 at 17:35:42:
A drained a transmission once of what looked about like what you described. It was dirty cream colored with no water at the bottom. I don't know what the oil started out as, likely to have been 30+ year old Hytran. I put it in a couple plastic milk jugs and left it. It was a couple menths before there was any visible change and a full year before it completely separated. After that, it was nearly 50% water.
