Recommend either a Hitachi, or 10SI Delco alt wired with 3 wires, the use of the 3 wire setup allows no battery drain when parked not running, it also charges with no revving to get it to excite. If it has no amp gauge, wire it as though the amp gauge was a continuation of the wire. If using the smaller Hitachi alt from a mid 1980s Nissan PU, the S is the same as the #2 terminal the L is the same as #1 terminal on the Delco. Use insulated spade connectors on either one for short protection. The thin wire from the starter to the ballast resistor coil side is the resistor bypass and comes from the I terminal (hot when cranking) terminal. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
