Re: IH 3088 TA replacement question for Pete23 or Owen
Posted by Owen Aaland on February 01, 2013 at 20:43:55 from (216.47.34.25):
In Reply to: IH 3088 TA replacement question for Pete23 or Owen posted by curtisk84 on February 01, 2013 at 19:11:45:
When I first started working on TAs there were no rebuilt units available so the only choice was to replace the parts that were needed. The first rebuilt parts were the gear and carrier that the sprag operated against. I rebuilt many units with reconditioned gears and carriers and clutch kits from IH. Shortly after Hy-Capacity, BMD, and others started to offer rebuilt units they started to offer heavy duty units which had improvements beyond standard parts. Once the HD units became available we seldom rebuilt units that were not in warranty. The HD units allowed us to sell a better TA which installed quicker and had a warranty beyond what the dealership would offer. After opening my own shop in 1985 I don't recall ever just replacing parts in the TA assembly. The rebuilt units were just a much better deal and carried a warranty that did not just depend on my shop.
TA Assembly, R&R or Replace: 15.2
With auxiliary fuel tank, add: .8
TA overhaul: 17.4
Rear crankshaft seal: 6.7
Subtract split engine to center section: 5.0
No additional time for clutch replacement since the clutch and flywheel are already removed to replace rear seal.
Good practice would be to also overhaul the MCV assembly.
MVC overhaul: 3.3
Since the MCV will already be removed for the TA replacement subtract MCV pump replacement: 2.3
Flat rate time for a TA replacement should end up something like this:
15.2 - TA replacement
0.8 - With auxiliary fuel tank
1.7 - Replace rear engine crankshaft seal
1.0 - Overhaul MCV
18.7
Add to this the actual time for additional items such as cleaning and additional time required because of rusted and damaged fasteners. Also add time for any additional repairs that needed. If the tractor is in relatively good shape I would expect the job to flat rate out at about 25 hours
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
