Re: Char-Lynn Question
Posted by IH fan on February 02, 2013 at 13:51:48 from (108.236.95.127):
In Reply to: Char-Lynn Question posted by farmall14 on February 02, 2013 at 09:47:51:
The first few degrees are easier as what you are doing at that point is just operating the internal valve. This is when it applies the pressure to the torque generator for the "power" to turn it. After that, when the tractor is not running, you still have a mechanical link-up to steer if need be, but it will turn hard. I don't recall how many degrees the valve movement it, but it's not much.
