Posted by El Toro on February 02, 2013 at 14:25:22 from (108.3.143.30):
In Reply to: 1947 farmall cub posted by Dan Lindquist on February 02, 2013 at 13:41:10:
You should run a compression test and post the readings. If the readings are low you probably need to rebuild the engine. You should then have those cylinders measured for wear by your local auto machine shop. If its worn too much you may need to have the cylinders bored oversize. They won't bore it unless it needs it. Good time to have crankshaft measured for wear. Buy your new bearings from them. It may also need new valve guides. It the old valves are close to 1/32" replace them. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
