Re: 1947 farmall cub
Posted by John B. on February 02, 2013 at 14:38:21 from (38.114.64.177):
In Reply to: 1947 farmall cub posted by Dan Lindquist on February 02, 2013 at 13:41:10:
Take a compression test as previously mentioned. Then squirt some oil in a cylinder and take another compression reading. If compression comes up your rings are bad. If no change in reading your valves are not sealing. Do this oil test procedure one cylinder at a time. Don't squirt oil in all the cylinders the same time.
