Posted by 36F30 on February 02, 2013 at 18:19:20 from (75.167.79.119):
In Reply to: W-30 priming cups posted by Fritz Maurer on February 02, 2013 at 17:30:29:
Quoting Removed, click Modern View to see The only time you should ever need them is if you switch from gasoline to kerosene too early before the engine is hot enough to vaporize the kerosene. If that happened you shut off the kerosene under the main tank and opened the drain on the carb and drained it, then opened the gas petcock up and flushed out the fuel bowl, close the drain and fill it back up with gas. The intake was still full of kerosene so the primer cups allowed you to put a measured amount of gasoline directly into the head and cylinders (prime them) so it would start again.
If you have to put fuel in them the small tin oil can that came with the tractor works quite well. They have no purpose on a gasoline tractor and many tractors had them removed after adding the gas or cold manifold.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
