Re: farmall cub govenor
Posted by screwstick on February 02, 2013 at 20:14:15 from (174.24.55.76):
In Reply to: farmall cub govenor posted by Joe Lankford on February 02, 2013 at 10:58:40:
When you installed the governor, did you ensure the internal weights were free?
What about the finger plate that pushes against the weights, is it installed and in good shape?
Where did you get the spring that is installed between the governor rockshaft and the throttle rod?
Are the holes worn or elongated as described above?
What about the woodruff key in the rockshaft going into the governor, is it tight or loose?
What, if anything, was done to the carb internals?
What are the exact RPM's at idle and when it goes full throttle?
Before you start cutting and modifying parts, I'm sure there is an easy fix to cure the tractors problems.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
